Archived
FME Cloud, version upgrade (one click)
Related products:Integrations
01011010
Forum|alt.badge.img+4
The process to upgrade an instance is a small hassle currently, I GREAT improvement would be say a "one-click" option.
helmoet
Forum|alt.badge.img+8
  • September 20, 2017
Not sure I found a quick document on upgrading Cloud instance...
helmoet
Might not be that clear however that version upgrade involves more than just the FME Server Software, so let it be a two-click action :-)
Here is documentation that I used: Migrating an FME Cloud instance
helmoet
By the way @aaronkoning if I restore an older build FME backup into a new Cloud instance, will the superuser credentials become the credentials in the backup? Or does ik keep the credentials supplied in the one-time-supplied file?
jeroen
Forum|alt.badge.img+15
  • June 5, 2019
An direct way to upgrade your FME server instance to a newer version would be game changer. Everything (IP, Subscription, alerts and stuff) would still work or be there and you only need some basic testing to see if it works instead of termination a whole instance.
spatialcase
At least a quick way to update the current release as point releases (bug fixes) as made available would be very useful
aviveiros
Participant
  • Participant
  • March 25, 2021
Totally agree with the 'one-click' option to upgrade FME Cloud. Unfortunately, I now need to migrate my FME Cloud instance after having upgraded to FME Desktop 2021 and getting the warning "To ensure best compatibility, an upgrade of FME Server is recommended" when trying to publish to my existing FME Cloud 2020 instance.
01011010
  • September 17, 2021
This should be job one!
j.botterill
Forum|alt.badge.img+69
@Test Test​  is this possible to maybe a few clicks in the Flow hosted consoleUpgrading_An_Instance_workflowhttps://docs.safe.com/fme-flow-hosted/FME-Flow-Hosted/Content/About_Instances/Upgrading-an-Instance.htm
