Archived
FME Academy should be friendly for macOS users too
Related products:Integrations
  • Oct 21, 2023 2:30 PM UTC
  • 0 replies
  • 13 views
Some courses in Academy are using Esri Geodatabase (File Geodb Open API) Reader/Writer (FILEGDB).
I don't think FILEGDB is supported by FME Form for macOS, I would recommend you to use OGC GeoPackage instead of FILEGDB.
I hope Safe will check if users can learn all FME Academy coureces regardless of their OS and revise them if necessary.
"The Esri Geodatabase (File Geodb Open API) reader/writer provides Geodatabase support without an installed Esri product on Windows and Linux;"
https://docs.safe.com/fme/2023.1/html/FME-Form-Documentation/FME-ReadersWriters/filegdb/filegdb.htm
