Archived
FME Flow - api token improvements
Related products:FME Flow
virtualcitymatt
I’ve been enjoying some great API token functionality on other platforms which I’d love to see on FME Flow.
  1. A notification before a token is due to expire. When configuring an api token I can specify an expiry date, however, without knowing how long the token is needed I tend to put in something soonish. Of course the application eventually breaks because I forgot to extend the life of the token. A reminder that a token is due to expire in 7 days or so would be really nice.
    If I don’t want an application to break I need to set this expiry time quite far in the future, e.g., a number of years. In this case if an application eventually stops being used then there is still an active token which I’d like to avoid. Setting shorter times coupled with a reminder would be much better.
  2. A “Last Used” field to indicate the last time a token was used. This helps to identify tokens which are no longer used so they can be removed/disabled.
These two features would be really nice to have. At the moment I would need to set up my own notification service to check if a token is due to expire. And at the moment I can’t tell when a token was last used.
LizAtSafe
Forum|alt.badge.img+16
  • July 31, 2024
NewOpen
todd_davis
Forum|alt.badge.img+23
  • July 31, 2024
Agree @virtualcitymatt
Currently I do a bunch of checks for tokens coming up for expiry, but that is via the API and therefore not easy for everyone.
Around your point about when it was last used. This is a very important one for me, as I find that people often make multiple webhook tokens for the same process, and I can’t tell which one is actively used without finding the token value they are currently using. I have also also raised the last date issue in the idea below
LizAtSafe
  • April 5, 2025
Updated idea statusOpenArchived
Idea merged into:
All the votes from this idea have been transferred.
