Open
Token Expiry System Event
Related products:FME Flow
  • June 5, 2017
  • 8 replies
  • 45 views
jdh
Forum|alt.badge.img+40
It would be nice if there was the possibility of setting up a notification that a security token for an FME Server account has expired (or is about to).
  • February 8, 2018
we need this too. perhaps the user list on the fme server admin portal could include a token(s) expires column
jdh
  • April 8, 2019
FME Server 2019 has improvements in token management, but it would still be very useful of we could set a notification for when a token is about to expire.
rylanatsafe
Forum|alt.badge.img+14
In FME Server 2019, we are able to now set very long expiration dates for tokens (for example, 2099) – giving users a "set it and forget it" approach.
Would that help for your workflows? Or do you require shorter lived tokens that are rotated? (In that scenario, presumably a scheduled notification to change them might also work?)
rylanatsafe
In FME Server 2019, each user can view their own tokens (click the User Icon > Manage Tokens) and there is an expiration column exposed.
jdh
  • June 4, 2019
Having a very long expiry will help with certain projects, but others do require cycling tokens.
rylanatsafe
@jdh @ajayel (and others interested in this), how long before expiry would you want a notification?
jdh
  • June 17, 2019
In the ideal it would be configurable on a per token basis, in the easier to implement at least 72 hours.
LizAtSafe
Forum|alt.badge.img+18
  • April 5, 2025
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
