Archived
FeatureWriter output port: option to create file checksum attribute
Related products:Transformers
  • February 27, 2019
  • 30 views
tomf
Forum|alt.badge.img+31
I'm generating files with my FME workspace for ingestion into another data management platform. In order to get the data ingested I need to also create a file containing a checksum (MD5 currently) for the data platform to check file integrity.
As I'm already using the FeatureWriter to create files before pushing them to the platform I would like to see the option of being able to create a checksum for the written file and adding it as an output summary attribute, then I can easily use the same workspace to perform the complete upload process.
  • February 27, 2019
It's an interesting idea, I sometimes need to do the same thing and am currently handling this manually in the shutdown python script.
Some questions for how this might be implemented:
  • How should such an option work for non-file based output formats? Databases, web services, etc?
  • If the output is a multi-file format (e.g. shape file), which files should be included in the checksum?
