Archived
Feature Merger Type as NONE on the FeatureMerger
Related products:Transformers
  • Jan 13, 2017 12:00 AM UTC
  • 31 views
jpvo
In many occasions I use a FeatureMerger to verify the match of ID between two datasets.
In this situation I really don't want to merge attributes at all. I use the Feature Merge Type "geometry" but then I need to restor the original geometry of the requestor (GeometryExtractor / Replacer).
My life would be much easier with an option "None" which checks the match between two dataset but leave untouched both requestor and suppliers so I don't have to worry about attribute accumulation.
  • Jan 13, 2017 10:25 AM UTC
Agree. In the interim, you can also use the InlineQuerier with a SQL statement like this.
select * from Requestor where ID in (select ID from Supplier)
  • Jan 13, 2017 10:53 AM UTC
I agree, but I must say my experience with the InlineQuerier has been less than fantastic when there is a lot of data, for some reason it seems to eat up memory at a rate that can create problems for the FME process later on in the workspace.
jpvo
  • Jan 20, 2017 10:23 AM UTC
It's a good idea but the InlineQuerrier does not immediatelly offer the same funcitonalities as the FeatureMerger.
Beeing forced to use the InlineQuerrier in place of a FM because you're scared of overwriting attributes doens'nt seem a good justification to me.
