Open
Feature Lines support in Civil3D reader
Related products:Integrations
  • Apr 9, 2021 7:25 AM UTC
  • 44 views
jasperwis
Forum|alt.badge.img+19
Topographic plans from surveyors that use the survey module of Civil3D typically contain lots of feature lines (and survey figure lines). It would be more efficient to read feature lines directly in FME. Together with its properties (from property sets).
Reader support for Survey Figure Lines would also be nice.
In 2021.0 release, a feature line that was used to build a corridor in the Civil3D DWG is read as an alignment, but no properties are found, neither with AttributeExposer. For an ordinary feature line (not linked to a corridor) nothing is read by FME.
rudewi
Participant
  • Participant
  • Apr 12, 2021 7:09 AM UTC
Yes, reading the feature lines directly in FME would really unlock the potential of the civil3D reader.
