Open
Extend the HttpCaller with an option to create a secure connection with a certif
Related products:Transformers
  • Mar 13, 2020 12:00 AM UTC
  • 6 replies
  • 77 views
lifalin2016
Forum|alt.badge.img+41
***Note from Migration:***
Original Title was: Extend the HttpCaller with an option to create a secure connection with a certificate
Please add an option to enable HttpCaller to create a secure SSL connection using a custom X.509 certificate.
Preferably enable providing the certificate in multiple format formats, e.g. both certificate/key separated formats and the joined format of pkcs12.
I can provide sample code that works in a PythonCaller (Python 3.7+).
nielsgerrits
Forum|alt.badge.img+67
Note from Safe: We had to turn off the formatting in this comment due to the community migration.
@lifalin2016 could you share the PythonCaller code? Would be very grateful to have a working example instead of working from scratch. Maybe via email if you don't like to have it on the net. For email see profile, firstname.lastname@companyname.com.
lifalin2016
  • Jul 2, 2020 6:18 AM UTC
I basically just utilized the socket and ssl modules, which dictated a full certificate split into a certificate and key files.
Here's a trimmed down version of my test code, which got quite large, as I was testing multiple things:
sample-script-connection.py
lifalin2016
  • Jul 2, 2020 6:21 AM UTC
I forgot to add, that I used OpenSSL Console to split the full certificate (PKCS12) into the two files.
The commands to split are as follows:
pkcs12 -in "input.p12" -nokeys -out "output.cer"
pkcs12 -in "input.p12" -out "output.key"
nielsgerrits
Thank you!
oliver.morris
Forum|alt.badge.img+14
@lifalin2016 if you are able to share your python code that would be very helpful, I am stuck at the moment and could really do with some guidance. thank you
oliver.morris
This is how postman enables it.
