Open
Expose sde version for Named ESRI sde connections so can be a parameter at runtime
Related products:FME Form
  • Sep 23, 2024 2:02 PM UTC
  • 87 views
mferwerda3
Expose sde version for Named ESRI  SDE connections in Readers or FeatureReader so can be a parameter at runtime.
Unless I am missing it, the only way to parameterize sde version at runtime  is to use embedded connections.  It would be nice to have this option for named SDE ESRI connections, as making a named sde connection  every possible sde version is not practical.
nordpil
Forum|alt.badge.img+12
  • Mar 6, 2025 11:59 AM UTC
A workaround would be to use arcpy to create a connection file in the workspace, I have done that a few times in Python Caller, then you would be able to use all the parameters there.
I doubt that it would be possible to specify from FME for an existing connection file, they live in the ESRI domain of things...
mferwerda3
  • Mar 6, 2025 2:07 PM UTC
That might work on a small scale, but we would have to have over 100 sde connections for what we are doing,  and then you would also need to have the credentials someplace  in that that ArcPy script to create the SDE connections. which brings up security issues of having credentials in a script or in a FME Workspace, nether is very good.
nordpil
  • Mar 7, 2025 9:07 AM UTC
You can have credentials in Database connections, and then you read them out in python using  fmewebservices.FMENamedConnectionManager()
I think it might even be more of a good fit for you if you have 100 sde connections, so that you don’t have to manage them separately. The negative is that it takes a bit of time for arcpy to create the connection.
You could also cache them if the values don’t change often.
In a scripted parameter, pseudo-code:
  • read selected db connection from another parameter
  • read version identifier from another parameter
  • Check if a .sde file exists that matches those exists in a cache folder
    • if yes, return that path
  • If not, read out credentials/server from db connection
  • Create new sde connection using arcpy and return that path
LizAtSafe
Forum|alt.badge.img+26
  • Apr 5, 2025 4:14 AM UTC
New→Open
