Archived
ESRI JSON output format should match ESRI Enclosed JSON format
Related products:Integrations
  • Nov 13, 2018 12:00 AM UTC
  • 18 views
venkat
Participant
It would be good to match ESRI JSON output format to ESRI Enclosed Format so that it can be used for AWS Athena tables.
jpsalva
Forum|alt.badge.img+3
  • Aug 7, 2019 7:08 PM UTC
Agreed.
the format 'com.esri.json.hadoop.EnclosedJsonInputFormat' is required for all Athena geospatial compatibility.
https://docs.aws.amazon.com/athena/latest/ug/geospatial-functions-list.html
Current workaround is to use
  • GeometryExtractor - Esri JSON for coordinates
  • JSON Templater - kludgey as requires complex workbench / or hand coded field definitions.
  • JSON Formatter
  • write to text file
