Released
ESRI Global IDs
Related products:FME Form
  • January 12, 2018
  • 8 replies
  • 277 views
Maintain ESRI Global IDs when writing an ESRI Geodatabase.
andybarnesosgb
Being able to use the ESRI GlobalID as an update of delete key on a enterprise geodatabase would be a great help to many workflows.
bruceharold
Forum|alt.badge.img+19
Also creating a GlobalID field in a GDB and a switch for preserving/creating input values on insert
  • October 15, 2018
Definitely need to be able to preserve existing GlobalID. This is important for key relationships for relationship classes between features and tables.
nampreetatsafe
Forum|alt.badge.img+14
Just wanted to let the Community know that this been implemented as of FME 2019.0! You should now be able to use FME to maintain ESRI Global ID fields when writing to ESRI Geodatabases. Check out the Documentation for the Esri Geodatabase (ArcSDE Geodb) Writer Parameters for more information on the Preserve GlobalID parameter.
After trying it out, please let us know if you have any feedback for us by commenting on this post.
  • October 8, 2019
A very good update indeed.
Will this update be available for file geodatabase writer as well ?
How about maintaining Global IDs when writing to file geodatabases? Is this possible?
salvaleonrp
Forum|alt.badge.img+23
I don't see a Preserve GlobalID option for file geodatabase.
fgiron
Forum|alt.badge.img+25
  • October 5, 2020
I've created a new idea to gain support for this feature in File Geodatabases. Upvoting is always easier than commenting: https://community.safe.com/s/idea/0874Q000000j0IbQAI/detail
