Archived
ESRI ArcGIS REST Query Service Transformer
  • August 25, 2017
  • 7 replies
  • 64 views
runneals
Forum|alt.badge.img+32
It would be nice to have a transformer where you could query a REST service (both Feature Service and Map Service) and have all of the fields be autoparsed out as attributes.
bruceharold
Forum|alt.badge.img+19
  • August 28, 2017
Feature service is there already with Online, Portal and Server feature service readers, but as you say image services are not supported.
runneals
  • September 22, 2017
I meant as a transformer instead of a reader, so you can take attributes from features and do a query on them with various REST services.
chriswilson
Forum|alt.badge.img+29
  • September 25, 2017
Would a Feature Reader not work for this? Building the URL based on certain attributes to then send as a query? Or are you trying to get the schema back from the service first and then work with that?
bruceharold
  • September 26, 2017
How about just using the Query API with HTTPCaller?
runneals
  • September 27, 2017
That's how I think I'm gonna have to tackle it now, but I have to then parse out the json (which means like 2+ transformers). I was hoping for 1 nice transformer where you could provide a URL and the where clause (and the other inputs that the query supports) and output the results as attributes (or a list - which ever makes more sense).
runneals
That might actually do the trick :P I never thought of using the feature reader!
chriswilson
  • September 29, 2017
That's what I usually use for reading online services, either with a creator beforehand or maybe a polygon going in to define a spatial filter (where possible). It's a very flexible way of doing things.
