Archived
Error message to update parameters FMEServerJobSubmitter
Related products:FME Flow
  • Jul 13, 2018 12:00 AM UTC
  • 35 views
jneujens
In a FMEServerJobSubmitter transformer, the published parameters are not automatically updated.
So if you change the parameters of a workspace (create or delete parameters), and call that workspace via a FMEServerJobSubmitter, it will cause a problem.
When running a process on FME Server that has an outdated FMEServerJobSubmitter transformer in it, the process is not even called or you don't get an error message.
I would suggest to throw somekind of error message so you are aware that you have to update the FMEServerJobSubmitter transformer.
kieranmg
Forum|alt.badge.img+3
  • Apr 9, 2020 1:15 AM UTC
I ran into this problem just now, and although the error did give me a rough indication as to where the issue was. It would be great if this was automatic so that we aren't maintaining two workspaces every time we make a change to one.
