Archived
Error: Import ALKIS-xml.-File into FME
Related products:FME Form
  • October 5, 2017
  • 47 views
Hello everybody,
im trying to import some XML-based ALKIS-Data into FME. Not even possible to create any Reader due to this Error:
XML Parser error: 'Error at file:'' line-0 column:0 message:unable to resolve host/address 'intra-prodaaaweb.vkv.niedersachsen.de''
An error occurred while attempting to parse the XML Schema document 'http://intra-prodaaaweb.vkv.niedersachsen.de/aaa-suite/schema/NAS/6.0/schema/Fachschema.xsd'
The XML Module halted on error, see the logfile for details
Failed to obtain any schemas from reader 'CITYGML' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
FME Session Duration: 0.4 seconds. (CPU: 0.2s user, 0.0s System)
Thanks a lot :)
Sabine
  • October 5, 2017
Hi @sabines,
Is it possible that you wanted to post this as a Question and not as a new idea?
If so, copy this to a new question. You will get more responses that way.
Unfortunately I do not know the answer to your problem myself since I do not work that often with xml at the moment. :)
Hello @sabines,
Did you solve this issue ? Because I have exactly the same...
