1. In WorkspaceRunner, it is better if we have option to disable the reader or writer, it will be better. Disabling writer/reader should be done with the help of input itself.
2. We are passing the parameters to workspacerunner with the help of csv/xls file. For each parameter even the format of attributes from coming in are same still we have to select manually. Automatic mapping of attributes with parameters will also help even better
