New
Enhanced scheduling of workspaces
Related products:FME FlowFME Flow Hosted
  • August 5, 2026
  • 38 views
lifalin2016
Forum|alt.badge.img+41
Scheduling workspaces could be enhanced by allowing multiple time periods on a single schedule.
I often have to duplicate a schedule to facilitate multiple time periods, which is irritating.
Maybe just enhance the CRON function with possible multiple values ?
s.jager
Forum|alt.badge.img+26
  • August 6, 2026
I’m not sure what you mean by multiple time periods. If you want a schedule to run multiple times per day for example, that’s easily done. Using the Cron option this would run every 4 hours: 0 */4 * * *, but Repeat on Interval also allows you to do that, as I’m sure you’re aware. So what is it you are trying to achieve?
Forum|alt.badge.img+63
I’ve helped a customer scheduling their pay-as-you-go FME Flow Hosted instance, multiple different timeslots across multiple days, so that ended up being several different schedules. For example:
Mondays and Fridays: 9:00-10:00 and 16:00-17:00
Tuesdays: 12:00-13:00
Wednesdays: 12:00-14:00
Thursdays: 16:00-18:00
s.jager
  • August 6, 2026
 For example:
Ah ok. Never seen or had the need for such complicated schedules myself, but yes, if you need something like that...
