Released
Encrypt/decrypt write/read on any database provided a key
Related products:FME Form
  • January 14, 2022
  • 27 views
paalped
Forum|alt.badge.img+5
I hope safe could do is a favor and let use a key to encrypt/decrypt when writing and reading data from a database. The goal is to make the database unreadable by any application that does not have a key. I think both data and column names should be encrypted.
LizAtSafe
Forum|alt.badge.img+25
SSL Mode is supported. Example: https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/postgis/add-postgis-connection.htm
