Open
Enable looping to a private input in an FMW file
Related products:FME Form
  • August 19, 2021
  • 60 views
theoconsortech
Forum|alt.badge.img+19
I realized that when you're doing a loop inside a linked custom transformer, you don't have the possibility to redirect the loop to a private input. If you do that, you'll have a "LOOPBACK_INPUT_TAG" error.
So you have to publish the input (even if you don't want it to be visible on the custom transformer).
theoconsortech
Edit : in the title, it should be FMX instead of FMW
