Archived
Enable Different WHERE Clause for Different Feature Types within the FeatureRade
Related products:Transformers
  • Sep 5, 2016 12:00 AM UTC
  • 119 views
Forum|alt.badge.img+54
***Note from Migration:***
Original Title was: Enable Different WHERE Clause for Different Feature Types within the FeatureRader
I'd like to be able to set different WHERE clauses, or choose to apply a WHERE clause to only one FeatureType within the FeatureReader.
  • Sep 19, 2016 2:43 PM UTC
I posted teh same idea! BUt then realized the where caluse box can be set by an attribute. So an attribute creator set to a conditional value will allow you to feed in different where clauses for each data set.
dms2
Forum|alt.badge.img+11
  • Nov 6, 2018 10:33 AM UTC
Can you give an example of that?
Thanks!
nic_ran
Forum|alt.badge.img+20
  • Jan 12, 2021 5:45 PM UTC
I still think this would be worthwhile and would bring FeatureReader capabilities in line with the standard reader.
For example, a standard SDE reader allows for a WHERE clause to be set at the reader level, but also allows for individual WHERE clauses on each of the feature classes within that reader.
The FeatureReader only allows for a WHERE clause at the reader level.
I know that individual FeatureReaders can be used for each required feature class but this makes the workspace larger and is less efficient from a performance perspective.
LizAtSafe
Forum|alt.badge.img+26
  • Apr 5, 2025 4:36 AM UTC
Updated idea statusOpen→Archived
Idea merged into:
All the votes from this idea have been transferred.
