Released
Enable Different 'WHERE ClAUSE' for Different Feature Types From the Same Reade
Related products:FME Form
  • Feb 18, 2016 12:00 AM UTC
  • 10 replies
  • 85 views
***Note from Migration:***
Original Title was: Enable Different 'WHERE ClAUSE' for Different Feature Types From the Same Reader(ArcSDE)
Enable Different 'WHERE ClAUSE' for Different Feature Types From the Same Reader To Avoid Creating Multiple Readers.
erik_jan
Forum|alt.badge.img+26
  • Feb 18, 2016 2:54 PM UTC
This can be done:
Using the WHERE clause on the Reader will use the same WHERE clause for all feature types except for the feature type where a WHERE clause is entered.
erik_jan
  • Feb 18, 2016 3:54 PM UTC
Or if you want to apply that setting to a selected number of feature types, you can enter the setting with a feature type and use the "Apply to" button to select all feature types that you want to change.
  • Feb 18, 2016 6:02 PM UTC
That is exaclty what I want, Different 'WHERE ClAUSE' for Different Feature Types.
But I can't seem to find the setting to define where clause for individual freature type.
I am using Arcsde reader.
Can you post a screenshot?
erik_jan
  • Feb 18, 2016 6:15 PM UTC
Sorry, but I am not an ESRI user.
But this is a screenshot of the ArcSDE Reader help:
  • Feb 18, 2016 7:05 PM UTC
Yes, But that Where Clause is gonna be applied to all the Table in the TalbeList.
I want different Where Clause for different table without creating another reader.
erik_jan
  • Feb 18, 2016 7:31 PM UTC
Not sure about SDE, but this is where it is in the Oracle Reader:
  • Feb 18, 2016 7:37 PM UTC
Aha, so it is a just a limitation of arcsde reader.
Ok, I give up, I will just create 2 reader instead.
erik_jan
  • Feb 18, 2016 7:56 PM UTC
As it seems to be not on the ArcSDE Reader feature types I will vote for this. If it exists on the Reader I do not see why it should not be able on the feature types.
fmelizard
Forum|alt.badge.img+22
  • Feb 21, 2016 2:19 AM UTC
Yes, there is a where clause for each feature type in the "Feature Type Properties -> Format Parameters" Tab
  • Feb 22, 2016 9:09 AM UTC
Esri legacy ArcSDE Reader
