Open
Easily override zip-file name on FMEServer Datadownload
Related products:FME Flow
  • Jan 5, 2018 12:00 AM UTC
  • 6 replies
  • 328 views
sigtill
Forum|alt.badge.img+25
Default filename using the DataDownloadservice is : http://fmeserver/fmedatadownload/FME_2D764B0C_1515155526785_73956.zip
Create an FME_SERVER_PARAMETER on FME Desktop like : FME_SERVER_ZIPFILENAME that can override this name if not empty. Then you can easily create a complex output-file based on both published parameters and attributes created during the workspace. For instance in a workspace you have:
PUBLISHED PARAMETER
Startfilename = "3Dmodels"
attribute created within the workspace:
timestamp = "20180101"
FME_SERVER_ZIPFILENAME = "Startfilename + _ + timestamp"
Will give the filename:
http://fmeserver/fmedatadownload/3Dmodels_20180101.zip
and automatically this will be the downloadlink instead of the default:
  • Jan 6, 2018 2:03 AM UTC
Agree that the suggestion would be useful in some cases. I think it would be better if the resulting zip file path could contain not only timestamp but also Job ID, in order to make each file path completely unique. Since the same workspace could be run with multiple jobs at the same time.
itsmatt
Forum|alt.badge.img+48
  • Jul 7, 2021 12:07 PM UTC
Still don't know why this isn't a feature. The UUID of the zip is a bit of a pain
  • Sep 27, 2022 10:57 PM UTC
Is this still not possible?
LizAtSafe
Forum|alt.badge.img+26
  • Jun 15, 2024 3:51 AM UTC
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
panda
Forum|alt.badge.img+20
  • Mar 28, 2025 1:52 PM UTC
Could use the name to include DateTime stamps!
rylanatsafe
Forum|alt.badge.img+14
