Open
drag transformers in high traffic area
Related products:FME Form
  • December 30, 2025
  • 5 replies
  • 111 views
gisbradokla
Forum|alt.badge.img+27
using a shift or control (any key combination with left click-drag) to “turn off” autosnap to transformer ports, connection lines, etc while moving one or more transformers into an area where there may be one or more connection lines right where you want to place the new transformer.
jennaatsafe
Forum|alt.badge.img+5
In FME Options, you are able to turn this on/off as an overall setting: FME Options > Workbench > Transformer Options > Use Drag-and-Insert Transformers.
For anyone reading this Idea:
  1. Were you aware of this being a control in FME Options? How would you see this working in conjunction with this being handled in a keyboard shortcut?
  2. If you were able to map keyboard shortcuts to actions however you wanted, what other actions that support workspace creation on canvas do you think we are missing?
jennaatsafe
New→Open
gisbradokla
  • January 20, 2026
I was not aware of this setting in options.
I only discovered after I posted this idea that it was already a feature. It does work to some degree but the perpendicular /ortho lock on it is still quite limiting.
I have noticed the auto search when I start typing a transformer name has gotten painfully slow. Why has that changed?
jennaatsafe
​@gisbradokla, regarding:
If you are experiencing issues here, please reach out to Support https://support.safe.com/hc/en-us/p/Support so this can be investigated.
phoeffler
Forum|alt.badge.img+13
  • January 26, 2026
I recently became aware of all of the FME Form/Workbench keyboard shortcuts - there are so many that are so useful! I found a PDF “cheat sheet” that could be printed out, but it was out of date, unfortunately.
I have experienced the same issue when moving transformers in a crowded environment, and was not aware of the relevant setting under Options. I do think that it would be useful to be able to more temporarily suspend the snapping function, similar to geometry snapping in ArcGIS Pro.
On Workbench 2025.1.2, the Quick Add is as quick as ever for me.
