Open
Display the canvas of the Workspace called when WorkspaceRunner is running
Related products:Transformers
  • November 8, 2015
  • 79 views
taojunabc
Participant
When running WorkspaceRunner,Cannot display the running status of the workspace called in real time.If can display the canves of WorkspaceRunner called on the run time, And like the usual workspace,Display the number of Feature that has been processed And real-time processing log. Then it will be more convenient to debug, And better grasp the running situation.
Of course, It is not necessary to display the working space at any time.So can add an option in the WorkspaceRunner parameter, such as the "show canves", only when this option is selected to show the canves.
  • November 8, 2015
I think it would be nice if the "real-time log" for running workspace could be displayed optionally with a log window similar to FME Quick Translator.
  • March 16, 2016
Great idea! This is bothering me for a long time, as I work a lot with parent and child models. Apart from that, would it also be possible to give not only a log file from a run, but also a file that contains all the stream counts at the end of the model run in a visual way?
kweller
Forum|alt.badge.img+8
  • October 11, 2016
This should apply to custom transformers as well, including linked.
