Released
disable calculation options in the statistic calculator
Related products:Transformers
  • June 19, 2017
  • 67 views
mygis
Forum|alt.badge.img+14
To have the option to enable or disable the StatisticCalculator calculation port be switching on at least one calculation mode; "Summary", "Complete" and/or "Cumulative".
The transformer would not process the unneeded calculation mode.
mark2atsafe
Forum|alt.badge.img+59
Does the 2020 release fix this issue? The Cumulative Results output needs to be manually switched on now. The other two ports I am not so worried about, but not having cumulative results (that I rarely used) is a bigger deal.
nelson
Participant
  • Participant
  • September 10, 2020
The cumulative port takes a lot of time and we don't use it.
In FME 2019.2 is there a possibiliy to disable it ?
LizAtSafe
Forum|alt.badge.img+25
  • June 15, 2024
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/statisticscalculator.htm
