Archived
disable a notification
Related products:FME Flow
  • January 18, 2017
  • 51 views
todd_davis
Forum|alt.badge.img+23
It is easy to enable/disable a scheduled process in FME Server and I would like to see the same ability for notification. This means you would be able to disable a notification when it doesn't need to be used for whatever reason.
rylanatsafe
Forum|alt.badge.img+14
  • February 15, 2018
Thank you very much for contributing your idea to the FME Knowledge Center, @todd_davis! We have identified that this request has already been captured in an existing idea – Enable/Disable publications/subscriptions/topics – and this posting will be closed.
We encourage you to upvote this idea (referenced above) and consider adding any comments to help define the criteria if you feel that it doesn’t cover all aspects of your request
