As there seems to be no way in FME DataInspector to make 3D solids "partly" transparent, like area filling is now, I suggest to add a rendering option for 3D features which allows to see through solids.
I have quite hard times to inspect the parts of a solid when I need to always rotate it so that the marked vertex/point is in foreground.
It would help greatly if it would be possible to see through the surfaces. One application would be to investigate CityGML data
see also: Knowledge Center Discussion
