Archived
DateFormatter: Expose automatically detected source date format
Related products:Transformers
  • Sep 15, 2016 12:00 AM UTC
  • 47 views
Use case: I convert dates to UNIX seconds (%s) to calculate differences, and then I may need to restore original format of the date attribute.
bruceharold
Forum|alt.badge.img+20
  • Sep 27, 2016 5:12 PM UTC
Hopefully the forthcoming date-handling improvements in FME 2017 will include a timedelta transformer so this use case will be satisfied.
Hi @crayxt
with FME 2017 DateTimeCalculator, you don't need to convert your dates into UNIX seconds to calculate differences.
I wonder if there are other scenarios where you would need to change datetime format and then restore the original format. In this scenarios, would you know what the original format was? Or would you rely on autodetecting the format?
Thank you in advance for your input.
revesz
Forum|alt.badge.img+22
  • Apr 26, 2017 10:37 AM UTC
It is not just converting to seconds but using Python caller (to carry out more sophisticated calculations) and formatting the calculated date/time same as the original is also useful to have the recognised format.
Another thing, as I'm aware DateFormatter works per feature. Let's say all locales are set to UK but I get a CSV exported from a system running on a US locale computer. '10/12/11' would be recognised as dd/mm/yy instead of mm/dd/yy but in another row 10/15/11 might be recognised correctly. It would helpful to see the recognised format as a column when debugging
