Archived
CSV flattener
Related products:FME Form
  • Aug 9, 2016 12:00 AM UTC
  • 57 views
I wondered why there is no CSV flattener, like JSON or XML flatteners. I had to process CSV in HTTPCaller's response ('_response_body').
So I made my own with Python caller (which is not utf compatible).
import csv, StringIO import fme import fmeobjects # Template Function interface: def processFeature(feature):     pass # Template Class Interface: class FeatureProcessor(object):     def __init__(self):         pass     def input(self,feature):         stringinput = feature.getAttribute('_response_body').encode("ascii","ignore")         reader = csv.DictReader(StringIO.StringIO(stringinput))         for line in reader:             for field in reader.fieldnames:                 feature.setAttribute(field, line[field])             self.pyoutput(feature)     def close(self):         pass
  • Aug 9, 2016 2:23 PM UTC
Did you try using a FeatureReader set to CSV and pointing it directly to the URL returning the data?
It might work in certain cases.
  • Aug 10, 2016 4:11 AM UTC
Hi, that URL required NTLM authorization, at least.
fmelizard
Forum|alt.badge.img+22
  • Aug 10, 2016 7:37 PM UTC
When you put a URL as the dataset, the Parameters should automatically be extended to provide you authentication options. Thanks for the interesting idea in any case.
  • Aug 22, 2016 4:09 AM UTC
well, the csv could be returned not only from FeatureReader. Generic idea is to be able to split attribute which holds CSV data.
