New
Create an FME option to connect to GCP (Google Cloud Platform) using “Workload Identity Federation” method
Related products:FME FormFME Flow
  • May 21, 2026 7:29 PM UTC
  • 45 views
josephlin
Observer
Please create an FME option to connect to GCP (Google Cloud Platform) using “Workload Identity Federation” method in addition to Service account (current option).
Thank you!
PierreAtSafe
Forum|alt.badge.img+11
Hi ​@josephlin,
I suspect we already support this. Would you be able to try using the Application Default Credentials option?
I’ll paste the message I got from our developer:
Application Default Credentials: Automatically authenticate based on the system environment. This will attempt to resolve credentials using the following sources, in order:
  • The credential file pointed to by the environment variable GOOGLE_APPLICATION_CREDENTIALS
According to the Google Cloud docs https://docs.cloud.google.com/docs/authentication/application-default-credentials#GAC, the GOOGLE_APPLICATION_CREDENTIALS environment variable supports "A credential configuration file for Workload Identity Federation".
Let me know if that doesn’t work for you please
