Open
Create a FME Server Dependencies list
Related products:FME Flow
  • September 11, 2020
  • 67 views
richardatsafe
Forum|alt.badge.img+11
It would be useful to have a list of dependencies for objects within FME Server. The example below focuses on workspace relationships and finds all the Repositories, Automations, and Schedules that are associated with a workspace and displays the report in the dashboards. This  workspace works on all versions   2019.2.1.0 (19813) and higher and uses the REST API calls to query FME Server.
What dependencies would you like to see? How do you want them displayed?
How to use:
1) Update the FME Server Web Connection parameter to use a connection to your server.
2) Publish to FME Server
3) Choose if you want a report on a specific workspace, or if you want all the workspace run with the parameter value "All"
4) Run workspace
5) View report from Dashboards
Forum|alt.badge.img+54
  • September 15, 2020
Is there supposed to be an attachment? "The example below...."
LizAtSafe
Forum|alt.badge.img+25
This is related to https://community.safe.com/ideas/flag-workbenches-which-are-part-of-an-automation-31875
