New
Copy/Paste parameters values from log file
Related products:FME Form
  • Aug 13, 2026 3:36 PM UTC
  • 31 views
jeand
When we need to rerun a workspace using the same parameter values from a previous execution, it can be quite time-consuming to go back to the log file and copy/paste each value one by one.
It would be very useful if we could select the parameter section from the log, or even better, drag and drop the log file directly onto the parameter section to automatically populate all values.
This would make debugging and rerunning workspaces much faster, especially when there are many parameters, and would also help prevent manual input errors.
 Ref:
carlm
Forum|alt.badge.img+23
  • Aug 13, 2026 6:17 PM UTC
In an Automation with a manual trigger you can provide a JSON with the parameters, it would be great to have a similar way to start a workspace. It would probably in another format for the local workspace (same way that we provide when running a batch file for example).
