We need a way to extract the properties of a coordinate system, such as the units. There is at least one custom transformer I found on HUB (CoordinateSystemMapUnitExtractor) but I think the capability to extract properties and use this data in the workspace logic should be available as a simple to use transformer, right OOTB. You can find more discussion on this here (specifically to the Units property, but it should apply to others).
