Archived
Coordinates System Locator
Related products:Integrations
  • Aug 1, 2017 12:00 AM UTC
  • 54 views
runneals
Forum|alt.badge.img+32
It would be nice to send a feature into a transformer that would tell you what coordinates systems are valid for that point. ie. State plane North, UTM 15, etc ... and possibly be able to do a reproject on that.
rylanatsafe
Forum|alt.badge.img+14
This is a very interesting idea... Would the incoming feature have a coordinate system? Would this be a test if the feature's coordinates are within range of coordinate system properties – i.e. the MIN, MAX values?
Perhaps if there was a way to extract all the coordinate system properties and test against it...?
I gave this a "Fast 15 Minute" attempt – didn't get very far, but my first idea was to test a feature (e.g. 1,1 in LL84) and see if I could reproject into coordinate system abc.
See attached template.. Disclaimer: Not my finest work. (Built with FME 2017.1 b17539)
@jlutherthomas When is the next FME Hackathon..?
coordsyslocator.fmwt
runneals
  • Aug 3, 2017 8:50 PM UTC
My idea is kinda similar to the UTM Zone Detector, which looks to use max/min of lat/long. I'm ending up using SDE FeatureClass of the boundaries for my solution.
