Gathering Interest
Coordinate extractor - first and last coordinates only
Related products:Transformers
  • Feb 14, 2017 12:00 AM UTC
  • 7 replies
  • 156 views
Forum|alt.badge.img+54
Add an additional option to the coordinate extractor to allow extraction of start and end coordinates/multiple specified coordinates
revesz
Forum|alt.badge.img+22
  • Feb 15, 2017 6:50 PM UTC
Do you mean extracting multiple coordinates? (You can use -1 in the coordinate index for the last coordinate.)
  • Feb 16, 2017 12:38 PM UTC
Yes, currently you can specify a coordinate, e.g. 0 for first and -1 for last, or get all coordinates, but if you want just the first and last coordinates you either need to use two coordinate extractors or extract all coordinates and identify the first and last from the list produced.
dellerbeck
Forum|alt.badge.img+7
  • Feb 11, 2021 10:39 PM UTC
Simple, add a coordinate extractor and return the -1 X \\ Y to end attributes. Right click and add an X \\ Y begin attribute, for the values use @XValue() and @YValue(). These will extract the begin index of a line.
trevorm
Forum|alt.badge.img+3
  • Oct 15, 2021 11:15 PM UTC
First and Last with x,y,z,m (measure) should also be considered as it becomes more and more popular with LRS / Routes.
I don't know if this solution will work for everyone, but I thought I would comment the LRS_GetRouteMeas does what this request wanted for me.
LizAtSafe
Forum|alt.badge.img+27
  • Jun 8, 2026 10:30 PM UTC
Open→Gathering Interest
andrewgmurphy
Forum|alt.badge.img+4
Definitely a thumbs up for this one. For topology checks being able to extract the First and Last in one transformer rather than having to chain 2 together makes sense. Even if there was a table interface where you could list the vertices you wanted maybe defaulting to start and end in the tool. It would also be good if there was checkbox option to “create points from extracted vertices”.
Why use 4 transformers when 1 will do!
daveatsafe
Forum|alt.badge.img+24
  • Oct 13, 2026 9:13 PM UTC
To extract the endpoint geometry, you can use a pair of Snippers in parallel. In the first, set the Snipping Mode to Vertex, and the Start and End Vertex to 0 to get the start point as a point. In the second, set the Snipping Mode to Vertex, and the Start and End Vertex to -1 to get the end point as a point.
