Archived
Control Connection Runtime Order at Input Port
Related products:Transformers
  • May 31, 2016 12:00 AM UTC
  • 92 views
The 'Set Connection Runtime Order' at the output port for every transformer has been introduced in FME 2016.1. It's very useful to control the feature flow, but it might be further better if the user could also control the connection order at the input port optionally.
In-Flow Control: Optionally the user can specify the order of the input connections flowing into a transformer. Also it should have the "Group By" parameter.
This would allow the user to control the input order for some transformers which combine features coming from multiple connections, such as RasterMosaicker, RasterBandCombiner etc., without using the Sorter.
The expected function may not be useful to most transformers, so it's also good to add the function to the Junction.
jdh
Forum|alt.badge.img+41
  • May 31, 2016 2:43 PM UTC
I could see this being useful for any transformer that has an input is ordered by group setting
