Archived
Connector With On/Off Param Options
Related products:FME Form
  • December 6, 2019
  • 55 views
robotix
Forum|alt.badge.img+10
Occasionally its nice to turn off a segment of an integration without having to modify and redeploy the entire integration.
A simple example scenario would be:
-Currently we trigger the workspace jobs with .bat files on a schedule and use the parameter references within.
-When 'x' happens in an integration do 'a', 'b', and 'c' [which are different transformations connected to 'x'].
-I no longer want 'b' to happen when 'x' happens.
-So I go to the connector param reference and set to off --ConnectorB "Off".
-If I ever want 'b' to happen again I can set it back to --ConnectorB "On".
I know, I know, there are probably other ways to do this. But isn't this easier? :)
This could be an option for some transformations also.
erik_jan
Forum|alt.badge.img+26
  • December 6, 2019
This looks very much like the option to enable/disable connections in a Workspace.
That option is available in the mouse menu, after selecting a connection or transformer or feature type.
Have a look at that option.
It even has a short key (Ctrl-E).
robotix
  • December 9, 2019
Thanks, but I understand how to enable and disable connections.
How do you do it with a published parameter? That is the suggestion.
When we promote our integrations to production we set them to read only and use a .bat file with params to run the workspace. In this scenario, I don't want to edit the workspace because it is in production.
erik_jan
  • December 9, 2019
Ah, I see.
I have used published parameters (e.g. ENVIRONENT) before in combination with a Tester or TestFilter to bypass sections that are only for DEV or TEST.
