Archived
Connect Multiple Obects at Once
Related products:FME Form
  • Oct 29, 2015 12:00 AM UTC
  • 6 replies
  • 118 views
fmelizard
Forum|alt.badge.img+22
The ability to select multiple objects, drag one of their input or output ports to a corresponding output/input port from another object and have them all connect.http:// imgur.com/S1LpfQU
fmelizard
  • Oct 29, 2015 3:51 PM UTC
Many to 1 selectionAbility to select many output points and connect to 1 input point in 1 operartion
mark2atsafe
Forum|alt.badge.img+59
That's already in our system - PR#11210
fmelizard
  • Oct 29, 2015 10:05 PM UTC
(Copying in the image so we don't have to go to imgur)
  • Jul 5, 2018 3:55 AM UTC
Ahh, OK, you use the "Auto Connect" feature of the "Feature Type Connections" thingy from View/Windows. Ref: https://knowledge.safe.com/answers/40588/view.html
How would I auto wire-up this ACAD to CSV Reader/Writer combo?
mark2atsafe
If the output schema is the same, just select the reader feature types and right click > duplicate on Writer. That'll create duplicates, but join them up automatically (and then it's simple to delete the original ones using Tools > Remove Unattached).
Otherwise - as mentioned - use the Auto Connect option in the Feature Type Connections window.
mark2atsafe
Quick demo of that first method - easier to just delete the items and not remove the writer: https://www.screencast.com/t/m2Vbn2bnId
