New
Compare Tool: Some improvements
Related products:FME Form
  • Nov 12, 2026 8:12 PM UTC
  • 0 replies
  • 3 views
itsmatt
Forum|alt.badge.img+48
Just a few ideas for the workspace compare tool:
  1. The zoom in/out is not working as expected. I’m constantly getting lost.
  2. If doing edits while comparing two workspaces every edit results in a refresh of the compare. If there was a way to turn off this auto updating it would be better. Doing edits with the auto update/compare means it quickly becomes frustrating to work with. It would be nice to be able to make changes and then click a “Refresh” button.
  3.  Inside many of the FeatureWriter it’s almost impossible to tell what has changed. For example in the is the schema definition has changed there’s no way to get a decent view.
    The columns are fixed so you can’t read the attribute names.
