Open
Clear generate workspace dialog
Related products:FME Form
  • March 16, 2020
  • 0 replies
  • 25 views
davideagle
Forum|alt.badge.img+21
I've been meaning to post this for a long time, because it's a frustrating issue but by nature of where it appears it's usually just when I'm getting into something so I've never prioritised posting this.
The 'generate workspace' dialog has a memory within the same session of the last workplace that you built. This IS very handy when you make a mistake adding readers and writers as you can go back and make the small change to a parameter without completely updating the whole dialog box. But, if you start a new workspace and have to update each parameter and perhaps are not thinking about reprojection for example, you might accidentally end up filling in a projection if you reprojected in the previous process!
Simple fix, please just provide us with a 'clear all' button on this dialog!
