Open
Civil 3D Survey Database support
Related products:Integrations
  • Jan 30, 2018 12:00 AM UTC
  • 56 views
Support connections to Civil 3D survey databases.
This would be helpful for syncing attributes in a projects survey database with other databases. More specifically point data in survey databases.
I know Autodesk added an api for survey in 2017 and they've upgraded the file type of the survey database in 2018. Project survey databases reside localy in the project directory and use data shortcuts in Civil 3D to connect the database to the projects drawings. The database is a Microsoft® SQL Server® Compact 3.5 database. New and converted survey database files for 2018 have the file extensions SDBX and SDXX.
LizAtSafe
Forum|alt.badge.img+26
  • Jan 30, 2018 6:59 PM UTC
