Archived
Check composite expressions
Related products:Integrations
  • Oct 25, 2017 12:00 AM UTC
  • 0 replies
  • 19 views
Forum|alt.badge.img+63
Both these composite expressions are wrong. That is to say, FME will probably run them just fine but the end result will most likely not be what you need.
I'd like to suggest adding a check to the composite expression: it will light up red if you're not using all of your sub-expressions -or- if you're using more than your sub-expressions.
