Archived
Change log-details on FME Server
  • March 22, 2017
  • 51 views
sigtill
Forum|alt.badge.img+25
When testing workspaces on FME Desktop I usually have many log messages turned on. When I publish them to FME Server I want to turn some of them off. When I go back again to developing I have to turn them on again on FME Desktop.
Solutions:
1. Add an option when pushint "Publish to FME Server" to change logging level when publishing a workspace - so you can keep the logging level you have on Desktop, and publish another loging level on the same workspace on FME Server
or
2. Be able to change loging-level on workspaces through FME Server GUI
  • March 22, 2017
Great idea, the current implementation isn't very logical. Another suggestion would be to have it as a setting in the workspace parameters:
This way it's clear that it's a workspace-specific setting and not a global setting.
geosander
Forum|alt.badge.img+7
  • April 30, 2017
Yes, I fully agree! Thanks for bringing this up. Also experienced in the past that the settings were not always updated when publishing to FME Server, but that could have been caused by the fact that I had 2 workspaces open...
My preference would be the first option (more fine-grained), but why not have both options, where the second one is a global option and option 1 can override that for an individual workspace?
fgiron
  • January 21, 2022
This completely makes sense. Particularly with workspaces intended for FME Server Streams, you don't want to have a massive log in the FME Server, and having to change this at the Workbench level doesn't make any sense.
I think the solution suggested by @david_r is the most flexible one (and probably easiest to implement?), that way you could decide at the runtime which logging level you want.
