Archived
Change default Landxml precision
Related products:FME Form
  • Nov 3, 2020 8:55 AM UTC
  • 0 replies
  • 20 views
sigtill
Forum|alt.badge.img+25
Related to the Coordinate Precision: https://www.explainxkcd.com/wiki/index.php/2170:_Coordinate_Precision
The Default setting for Landxml WRITER is 12. Can this be changed to for instance 4? A lot of people use this as default (Valid values range from 1 to 15. The default value is 12, which was the default fixed value for LandXML 1.1. A lower number of digits can dramatically reduce the size of the output file when writing a large number of coordinates.)
