Released
Chain workspaces within a single automation together - abort all when one fails.
Related products:FME Flow
  • August 13, 2019
  • 86 views
sigtill
Forum|alt.badge.img+25
***Note from Migration:***
Original Title was: Chain workspaces within a single automation together - abort all when one fails.
When you use a Jobsubmitter to start multiple workspaces and those also might use Jobsubmitters, it is nice by using the FMEJobSubmitter that if any child-workspace stops then also the main-workspace fails. It would be nice with this behaviour also in FME Server AUTOMATIONS. So that you could "group" and cancel all other actions when one of them fails. Same behaviour as running FMEServerJobsubmitter
rylanatsafe
Forum|alt.badge.img+14
  • November 8, 2019
@sigtill - Thank you for contributing to the FME Community with this idea!
To help me understand better, can you walk me through a workflow?
In the image you provided, if any of the workspaces chained together fail, the FME Server Automation will simply end right there. No workspace downstream would run – as none are connected to the "Failed Port" of the 'Run a workspace' Action.
LizAtSafe
  • April 5, 2025
Open→Released
LizAtSafe
  • April 5, 2025
Use the Split-Merge Block in an FME Flow Automation
