Released
Catch SQL Executor errors
Related products:FME Form
  • February 1, 2016
  • 8 replies
  • 34 views
Forum|alt.badge.img+5
If your Sql executor crashes, your workbench crashes.
So is it possible to add a new output (Failed) for Sql Executor ? this new feature would be very appreciated...
Or what is the best thing to catch every exception of Sql Executor ?
Thank you
erik_jan
Forum|alt.badge.img+26
  • February 1, 2016
The new SQL Editor, used in all SQL transformers in FME 2016 has an option to test SQL statements.
You can read all about it in this blog by @Mark2AtSafe:
http://blog.safe.com/2015/10/fmeevangelist139/
fmelizard
Forum|alt.badge.img+22
There is a little know option in the SQL transformers that somewhat handles this problem. If you prefix your SQL Statement with a hyphen "-" then if the command fails, the SQL transformer continues on. e.g. if you have the following in your SQL Statement
- DROP TABLE test_table;
CREATE TABLE test_table ....
then if "test_table" doesn't exist the DROP TABLE command will fail but the SQL transformer will ignore the error and continue processing.
  • February 2, 2016
Thank you !
This option is only available for 2016 ?
  • February 2, 2016
Thank you !
fmelizard
Sounds like it might be time for a <Rejected> Port. I'll alert the appropriate authorities.
fmelizard
  • February 15, 2016
No it has been around for a long time.
fmelizard
  • February 15, 2016
The <Rejected> Port has been added to the SQL transformers in FME 2016.0.
Now in the above example
FME_SQL_DELIMITER ; - DROP TABLE test_table; CREATE TABLE test_table ....
the SQL transformer will continue to ignore the failed DROP command.
However
FME_SQL_DELIMITER ; DROP TABLE test_table; CREATE TABLE test_table ....
will result in output via the <Rejected> port with an attribute _reader_error detailing the error message.
  • February 16, 2016
Didn't know that one. Just tried it with SQL Statement To Execute Before Translation and works there too!
