There is a CAT (Column Aligned Text) Reader - however no writer. You can use the Textfile Writer with TAB - however it is not the same. And you can build a string with fixed number of rows using the Stringformatter to be sure each column is aligned - but still....
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
