Archived
Cannot insert Text when my Post contains an Image
Related products:Website
  • Mar 12, 2026 2:26 PM UTC
  • 5 replies
  • 103 views
927474939
This is a screenshot from FME community. I want to create a post, but it’s impossible to insert text at the start of the post or move the image.
Does anybody know how I can add text to the start of the post?
It should be possible to insert text at the start of the post even when the post contains an image file. And it should be possible to do that without having to remove the image and then upload it again just to move it to a different place.
geomancer
Forum|alt.badge.img+71
  • Mar 12, 2026 2:55 PM UTC
Yes you can.
But maybe it’s not very intuitive.
When you select (click on) the image, a symbol appears at the top left corner of the image.
After clicking this symbol, you can drag and move the image somewhere else in your post, like below some text.
After dragging the image the text will appear above the image.
927474939
  • Mar 12, 2026 4:46 PM UTC
​@geomancer You are right, it's possible to move the image with that icon. But it’s really not intuitive.
Usually you can move the cursor to the start of a text field or document using the arrow keys. This should be possible in a normal text editor but it’s not possible in this one.
However I can move the cursor to the left of the image by clicking in the text field. But it’s impossible to type if I do that. It does not react at all. That’s not how a text editor is supposed to work. A cursor symbol clearly means that the user can type in text. But it doesn’t work.
The cursor is where the red arrow points on the screenshot but it’s hard to see because it’s right next to the image and has a dark color like the image and is only 1px wide.
danielleatsafe
Forum|alt.badge.img+31
Thanks for your feedback ​@927474939. I’ve shared this in the Gainsight community under their product improvements page: https://communities.gainsight.com/ideas/improve-text-editor-behaviour-when-editing-posts-with-images-30541
danielleatsafe
New→In Development
danielleatsafe
In Development→Archived
