Archived
Caching only connected ports
Related products:FME Form
  • November 21, 2024
  • 5 replies
  • 63 views
danilo_fme
  • danilo_fme
    danilo_fme
dustin
For all transformers, it would be nice if feature caching would only cache for ports that had a connector on it. This could either be global functionality, or even better would be some kind of parameter that allows the user to cache or not cache un-connected ports.
stewartatsafe
Forum|alt.badge.img+5
Hi Dustin. Can you explain what your frustration is with the current behaviour, are you looking for the canvas to just be cleaner or is it performance related?
dustin
Forum|alt.badge.img+30
  • November 22, 2024
Reduction in overhead when using caching. An example would a TestFilter where 1000000 features are being input, only 100 are being passed to additional process with the rest essentially being dropped. Caching of those 900,900 features creates unnecessary processing time.
bwn
Forum|alt.badge.img+26
  • November 25, 2024
I’m wondering out loud if, rather than have this as a Transformer Parameter, perhaps this could be more easily done as a Connector Parameter?
Doesn’t need all different Transformer Dialogs changed then.  Just make it a property of the Connector(s) as to whether the Output Port(s) that feed them whether to Cache those Output Port(s).
Connection Options.
1. Default =  Resets all Connectors to that Transformer to Cached (and not just the Selected Connector).  Also sets any unconnected Output Ports to Cached.
  1. Cache Only Selected.  Will turn Caching On for only currently graphically selected/highlighted Connectors.   Any other Connectors to those upstream Transformer(s) not selected will conversely go to “Don’t Cache” along with any unconnected Output Ports
  2. Don’t Cache Selected.  Will turn Caching Off for only currently graphically selected/highlighted Connectors.   Any other Connectors to those upstream Transformer(s) not selected will conversely go to “Don’t Cache” along with any unconnected Output Ports
LizAtSafe
Forum|alt.badge.img+15
  • December 16, 2024
NewOpen
LizAtSafe
  • April 5, 2025
Updated idea statusOpenArchived
Idea merged into:
All the votes from this idea have been transferred.
