It would be nice to be able to multiple select failed FME jobs and batch resubmit from the 'Jobs' page - rather than having to manually go into each job and resubmit individually.
Yes, Agree with the idea. FME should provide options or process to re-trigger the failed jobs sequentially based on job id in bulk mode. Should not generate new Job ID, instead use the current Job ID. Its very hard to track the changes if FME is generating new job id every time the failed jobs are re-triggered.
