Archived
Bulk Offsetter/Warping (using joiner type function)
Related products:FME Form
  • Apr 21, 2016 12:00 AM UTC
  • 29 views
I work with input in files that are not always aligned & would like a way to process multiple files that require DIFFERENT offsets (or warps). My concept is to use a joiner type setup where the filename is matched to the join file & if found processed. The join file would have either 3 or 5 columns: filename, offset_x, offset_y or filename, source_x, source_y, target_x, target_y. Output ports would be "changed" & "unchanged". the output could then either be reprojected or warped as needed using existing transformers
I have been working on a beast with this same problem. you would need an additional column to warp 'seq' so file, seq, _from_x_, _to_x_, _from_y_, _to_y_ since warping requires multiple points
